Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-30-2008, 07:31 PM
mike561 mike561 is offline
Steering box
I just had front end work done today to finally be able to get an alignment (the alignment was REALLY bad, at a negative .71 for the front) i was told i may need a new steering box though cause we tightened the bolt on it but it still has some play in it, if i gotta tignten it a little more im not gonna knock it out of alignment again am i?
2006 Chevy Cobalt LS
Old 05-30-2008, 09:03 PM
Re: Steering box
fyi by new front end work i mean inner and outer tie rods, sway bar bushings etc.
Old 05-31-2008, 01:12 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Steering box
The alignment, per se, will hold however the vehicle will 'hunt' on the road - meaning it may not stay straight, not pulling, but with a tendency to move one way and then another.
This happened to my own car when the gearbox went south. Replacing it solved the problem.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-31-2008, 02:09 PM
Re: Steering box
yeah i can let go of the wheel and it stays straight but i can feel it swerving a little bit
Old 05-31-2008, 03:30 PM
CD Smalley CD Smalley is offline
Re: Steering box
If you need to replace it the steering box, see if you can find one for a 9C1. The increased ratio will give you a better, less darty, feel while driving.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 05-31-2008, 04:54 PM
Re: Steering box
alright good to know
Old 06-01-2008, 09:23 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Re: Steering box
I wonder if i need to replace mine also. Whenver i go over a bump the car will sort of swerve sometimes and it seems like its a little more than normal.
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 06-01-2008, 10:49 PM
silicon212's Avatar
Confoundingly Lucid
Re: Steering box
Usually, that's a sign of a bad shock, or bad shocks.
