Old 05-30-2008, 05:20 PM
Zman_09 Zman_09 is offline
Rough idle and hesitation 92 chevy 1500
I have a 1992 Chevy 1500 with a 350. I started it up the other day and it took about 4 trys before it stayed running. the idle drops to 200 rpm and then jumps to 1500 repeatedly, and when i try to excelerate it hesitates severely and i have no check engine light on... any ideas?
Old 11-07-2008, 07:37 AM
lowedawg20 lowedawg20 is offline
Re: Rough idle and hesitation 92 chevy 1500
Did you find the problem? My 93' is doing the same things.
Old 11-07-2008, 08:57 AM
Scrapper Scrapper is offline
AF Premium User
check your vaccum lines and try some sea foam.and i'd check gas pressure tested. how longs it been since you done a tune up? like air filter,gas filter, plugs,wires? if you havn't change plugs i'd do a cyl check if you got a guage. so how did you find out? did you have the fuel pressure checked?
Old 11-07-2008, 07:13 PM
it was the fuel pump. thank you for the post though
Old 11-08-2008, 12:03 PM
AF Premium User
how did you find out fuel pump did you get it tested like i said?
