Check Engine Light - PO401????
OK guys . . . my check engine light came on this morning. Went to Checker Auto and they pulled the following code/description:
PO401 - "Exhaust Gas Recirculation Flow Insufficient Detected" Any thoughts as to what this is? |
Re: Check Engine Light - PO401????
Your EGR and EGR tube are plugged up. Read up in the FAQs on how to clean it.
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
Is this something that is "harmful" or is it more something that will just affect performance/emissions a little until I can clean it? |
Update . . . looks like cleaning the EGR may have done the trick. I just cleaned it out and disconnected the battery for a few minutes. No more Check Engine Light! I'll just keep an eye on it and see how it goes.
This was a really easy DIY thing to do. I am embarrassingly non-mechanically-inclined, but this was a breeze using the instructions from the FAQ. I have to say that this forum is just fantastic . . . this could easily have run me a couple hundred bucks at a repair shop to get diagnosed and fixed. But thanks to this site, I knew to go to an auto parts store to get the code identified (FREE) and then all it took was 15 minutes and a $3 can of intake cleaner. So if this was the solution for the issue, then what a bargain to fix it. |
let us no how it goes im not convinced the ck eng light will remain off
Any thoughts on other potential causes . . . just so I can be prepared for "round 2"? |
Well . . . it's back. Check Engine light has been going on/off intermittently over the last week or so. Yesterday it came on in the morning, so I stopped at Checker Auto Parts and they read the code--same PO401.
I went ahead and cleaned the EGR port again after that. The first time I did it, I did not use the full can of intake cleaner (I only used about 1/2). So I used a whole can this time around, disconnected the battery to clear the code, and we'll see how it goes. Are there other causes for this error, or is EGR pretty much it? |
make, year, model,& miles would help
The first time the EGR ever got cleaned out was last month when I first posted . . . so maybe there is just so much crap built up that it will take more than one cleaning to get the error to stop showing up? |
I have cleaned the EGR port 4 times,replaced EGR valve twice,replaced MAP sensor and still have the check engine light (p0401) come on at times. I have all but given up trying to fix unless someone else has any ideas?
Is that the same code for a loose or leaking gas cap?
I too struggled with this for a while. The key for mine (2000) was to not focus on the EGR valve itself, but to remove the intake manifold and get into the throttle body where sure enough, the EGR pipe was clogged at the tip. A high-pressure can of carb cleaner and a straightened wire hanger later, the carbon broke off and cleared the tube.
Next time, I am going to get a test-tube brush to really get in there. For two months, mileage has increased and no MIL mean I did a great job! -Douglas
2000 Honda Passport LX - 4x4 - AT (Second Owner) 2004 Honda Civic Hybrid (Original Owner) OnTarget Consulting |
--Dave 1999 Rodeo LS 3.2 4x4 5 Speed 32x11.50-15 BFG T/A KO 3" Lift - Rancho 9000x Rear No-Slip Locker Flowmaster 2.25" 50 Series There is a very fine line between "hobby" and "mental illness." - Dave Barry |
Thanks, guys . . . I'll just keep an eye on it and see what happens. I'm not very mechanically inclined, unfortunately (not when it comes to cars anyway), so not sure I would even know what to do in order to remove the exhaust manifold and clean around in there. I'd probably screw it up worse.
