Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-30-2008, 11:24 AM
fst100 fst100 is offline
Exclamation newbie: bought a 1990 eclipse 1.8L
hey everybody, i just bought this as a beater car to learn to drive 5-speed. test drive a yesterday and the clutch is really tight, needs possibly adjusted. the car has oil sludge built-up on the side of the motor, im guessing it needs new valve cover gaskets. which brings t some questions on maintenance.
1-what part number is for the valve cover gasket at places such as advanced auto/pep boys? would that stop the oil leak assuming thats where its coming from?
2-how many quarts of oil does the motor take as well as a part number for the oil filter? the oil when i checked it was black *blah*
3-im going to check the tranny oil and i understand theres the drain and also a fill plug. whats the general oil to use when i drain out the old oil via the drain plug? also when i refill i should fill it via the fill plug but should the drain plug also be left open so i know where the level is at?
4-whats the stock idle on the 1.8L?
5-the 1.8L is known as the 4G37?
THANKS!!!!
Old 06-01-2008, 04:30 PM
nofear39427 nofear39427 is offline
Send a message via Yahoo to nofear39427
Re: newbie: bought a 1990 eclipse 1.8L
Just answer a few of your questions.
The 1.8L is known as the 4g37
It holds 4 quarts of oil and takes a 2950 Fram oil filter
My 1.8 idles at about 800 rpm
I would call the dealer for any valve cover numbers
I hope you have good luck with your Eclipse my 1.8 has 320 thousand miles on it uses some oil but it still running strong...knock on wood
Old 06-01-2008, 05:28 PM
thankas, however i just found out that my ECU fried >.<. now im trying to find another ECU replacement but unsure if the non-turbo 1gen 5-speed ECUs are interchangeable. if so are there any wires needed to swap or relocate b/t the different years?
Old 07-13-2008, 03:07 PM
chamilun chamilun is offline
im converting my 94 1.8L to EV, so if the ECU is compatible, you can by mine.
make me an offer
Old 07-13-2008, 03:08 PM
im converting my 94 1.8L to EV, so if the ECU is compatible, you can buy mine.
make me an offer
Old 07-15-2008, 12:41 PM
thanks but i did some research and only 90 fits 90 and 91-92 fits 91-92 etc specifically.
