Old 05-29-2008, 10:05 PM
rairigh915 rairigh915 is offline
99 gp gt Repeated problem
99 gp gt. 3.8
Cylinder 6 spark plug keeps getting hairline cracks in the insulator part. Causing a bad misfire. Compression good. Coil good. Plug wire good.
Should i assume injecter?
Old 05-30-2008, 09:26 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 99 gp gt Repeated problem
What brand and heat range plugs are you using? Sure you are not over torquing the plugs and are you using the metal heat shields?
Timeslip 08/12/06
AF Community Guidelines
Old 05-30-2008, 12:48 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
In addition to Bob's questions, are you losing coolant, and if so, do you notice any discoloration (orangish if you're still running Dex-Cool, or yellow/greenish if you switched it over to non-Dex-Cool) on the plugs?
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-30-2008, 01:46 PM
No signs of coolant loss. Im using ac delco rapidfires 14. Yep using heat sheild. Id say no to the overtightening question
I switched injector today so we'll see what happens.
Old 05-30-2008, 03:47 PM
BNaylor's Avatar
Your problem is most likely the Delco Rapidfire 14 plugs which can be used but not really a good replacement plug for the OE double platinums. I recall there was a major manufacturing defect concerning them. Here is a pic of one and you can clearly see a crack with carbon tracking. They were exchanged for other brand spark plugs and no further issues.
Timeslip 08/12/06
Old 05-30-2008, 04:15 PM
richtazz's Avatar
I agree again Bob. The ceramic insulator failure is the reason Delco is starting to phase out Rapid-fire plugs. It's also the reason I would never use them.
