Old 05-29-2008, 09:50 PM
Rewhaley Rewhaley is offline
Wire
I have 2008 silverado and need to run 2 wires through the firewall. need help locating a spot. thanks
Old 05-30-2008, 08:50 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Wire
Just look around for the best open spot.
Or if there is a big rubber groment with just a few wires add a couple of more to it.
MT
MT
Old 05-30-2008, 08:54 AM
Re: Wire
I found one but was not sure if it went through the fire wall. thanks
Old 05-30-2008, 09:13 AM
MT-2500's Avatar
AF - Advisor
Re: Wire
Always check both sides before going threw the firewall.
Good luck.
MT
MT
Old 06-02-2008, 10:46 AM
Tdragone Tdragone is offline
Re: Wire
Get a metal coat hanger; bake sure there are no burrs on the end to nick wiring insulation; and feed it through. You'll then know if it goes all the way through or not.
In my 2002; nothing went through the firewall; I took all the carpet/sound deadening out looking for a place. There was a huge wiring plug/pass through with connectors on either end that sent all wires through to the engine.
There WAS a spot under the E brake pedal where I found a centerpunched hole with nothing behind it. I used this spot to punch through for the +12v for my amp and AC Inverter.
Good Luck.
