Go Back   Automotive Forums Car Chat > Hyundai > Azera
Old 05-29-2008, 08:25 PM
edbard edbard is offline
Rear tire wear
I have a 2007 Azera Limited 22,000 miles and having inside rear tire wear. The tires are tilted inward toward the car body. Dealer said alinement was fine. A few thousand more miles and the tires are very worn to the inside. Anybody look at the rear tilt of your tires? I notice it on brand new Azeras sitting on the dealers lot.
Ed
Old 06-22-2008, 10:13 AM
Snaglepus Snaglepus is offline
Question Re: Rear tire wear
Ed
I wonder if you are rotating your tires periodically?
Old 11-13-2008, 04:06 PM
mahout mahout is offline
Re: Rear tire wear
Ed
Regardless of your dealer ciomment, if the tires lean-in enough at the top to easily see it and your tires wear heavily on the inner side of the tread, the camber is wrong. Have the alignment checked at an independent alignment center that has a good reputation.
Either that or you carry very heavy loads in the back seat or trunk.
Old 11-26-2008, 01:23 PM
Smile Re: Rear tire wear
on the dealers lot.
Ed
Have you had your rear alighment checked?
When my alighment shop cut my front coil springs, (what I refer to as the mahout
modification,) I had him do an alighment on both the front and the back.
He told me the rear alighment was off and that the rears were "toeing out."
Doesn't that cause the insides of the rear tires to wear prematurely,
especially if they are not being rotated periodically?
BTW, is there any camber or caster adjustment on either end of the Azeras?
Delfin
aka snaglepus
Old 01-20-2009, 12:34 AM
shankyrhodes shankyrhodes is offline
Re: Rear tire wear
It is best site to used the advertise used new cars,boats, bikes with us across the whole globe for free. do not miss this offer and same in newspaper & sites. yes you read it right you can advertise your boats, cars, and bikes free of charge till its sold. please visit this this site again and watch the grow.@@@@Used Cars
Old 02-10-2009, 09:12 AM
jsinton jsinton is offline
Re: Rear tire wear
Take it back to the dealer. Here is alignment specifications:
AZERA
(TG)
Rear Camber
-0.5° ± 0.5°
(0.5°)
Rear Toe
2 ± 2
(1 ± 1)
Old 09-06-2009, 02:20 PM
Re: Rear tire wear
It turns out early Azeras had a problem with cheap struts in the rear that leads to tires wearing out. Lots of cases on other forums.
