| F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
power window motor?
well it might be my cars time...the driver side window almost never can make it all the way up or down in one shot..eventually if you wait long enough in between tries it will make it, but its getting annoying!!! the passenger side is almost the same thing to..i have a 2000 trans am ws6..anyone have experience in swapping the motors in the door? and what brand to get? any help would be nice..thanks
jeff
2000 trans am WS6 FTP 85mm intake 85mm jet maf 85mm summit throttle body 85mm bbk ssi intake fast fuel rails 30lb ford racing injectors spohn strut bar msd ignition coils msd 8.5mm spark plug wires edelbrock shorty headers upgrade cam/ port and polished heads SMG dyno tuned ( 375 rear wheel hp ) magnaflow cat back slp y pipe umi bolt on subframe connectors umi rear control arms umi panhard bar 4:10 rear end gears stage 2 spec clutch |
Re: power window motor?
another thing..the window is stuck now, like 3/4 the way up..i can hear a buzzing noise coming from under the dash when i hit the window button..but it dont move..only the driver side window is stuck..passenger works fine...i think its a relay buzzing??? could it be a relay problem? not a motor??
