| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
eclipse acting wierd
when i go to start my car, it revs up to 2 grand but instead of dropping to 1100, it drops down to like 500-600 and barely stays runnin gunless i give it some gas. this only lasts for about 20-30 seconds and then its fine. so now i drive it and after about 2 miles it dies. when i try to start it back up it revs up to like 1300 and then dies immediatly. i keep leeting it start like this untill it finaly revs up and can drive again. sometimes it takes 3-4 time sometimes it take a half hour. my dad said someting about vapor lock. but are there any other things as to why its acting so weird. other then the "moments" my car has, it takes off pretty good so as far as i know i dont think its something major.
Re: eclipse acting wierd
Sounds like your Idle Air Controller (IAC) is going bad or your front O2 sensor is shot. Is your check engine light on? Also, what year and trim do you have?
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
older 95 with a 420a. if i have the iac unplugged will it cause all this. and heres a new problem when it finnaly idles, rough anyways, when the radiator fans kick in ( which i found out didn't turn on so i fixed them) the engine almost dies. i also just checked the altenator and im getting 17 volts. i'm starting to think the computer is fried cuz i believe the voltage regulator is in the pcm which i can't fix.
Tim 1990 Talon AWD 2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink, PTE SCM5031
I thought that the voltage reg was built into the alternator?
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
yeah i think it is now. but i read somewhere in my haynes manual (thats probably why, haynes sucks) that the voltage regulater wasin the pcm. that must be a secondary one. i hope i didnt wreck any of my computers by rynning it with that many volts
