Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 05-29-2008, 02:15 PM
MTrachy MTrachy is offline
2003 Rear Wheel Bearing
I have to replace my left rear wheel bearing. I have never replaced a wheel bearing before, can anyone give me some tips?
Thanks.
MT
Old 05-29-2008, 06:42 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 2003 Rear Wheel Bearing
Jack up vehicle and place on jack stands.
Remove wheel, brakes and rotor.
Remove rear end cover.(Have pan there to catch all grease)
Place vehicle in neutral.
Use 5/16 or 8mm wrench to remove locking bolt from pin. Be careful, these can break fairly easily.
Remove pin from rear end. You may need to spin driveshaft to get pin to line up so it will come out.
Push in on axle so you can remove the locking "C" clip.
Remove axle
Remove axle seal.
Use puller to remove old bearing.
When installing, the bearing is easily seated back in the axle. A few light taps with hammers will seat it. Just be sure to hit on outside portion of bearing. Install new seal with hammer again. Just go flush with axle. Then instal axle, pin, locking bolt. Clean rear cover, use silicone gasket maker as seal. Fill up rear end with proper grease. Install brakes, wheel, remove from jack stands and have a beverage of your choice. You have completed the repair.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 05-31-2008, 03:11 PM
carlos80 carlos80 is offline
way2old covered everything just remember that if it has a limited slip diff u have to add a friction modifier fluid
