Old 05-29-2008, 11:01 AM
phizzle phizzle is offline
Exclamation 96 grandam front turn signals and emergency lights are out.. please hellllllp! =)
hi all just saying thanx in advance.. this forum has always been a big help to me and i along with tons of others im sure appreciate it!!!!..
this is what i have had done concerning the lights
a long time ago.. the front headlight went out
my mechanic couldnt figure out what it was
the bulb was good... fuse was good..... but light just wouldnt work..
so he wired one the passenger headlight to the left headlight(broke one).. and boom they both worked
later i noticed the flasher blinking fast in the car..
and front emergency lights and the front blinkers dont work..
nore to the fog lamps
when i turn the headlights on manually the turn signal lamps also light up
everything works fine in the rear both signals and emergency lights
what do you think? i was tryin to sell this car today.. and jus noticed this problem i hate it!!!!!!!!!! lol
thanx again
Old 05-29-2008, 03:34 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 96 grandam front turn signals and emergency lights are out.. please hellllllp! =)
Have you checked the bulbs? They are dual filament, so it is probably the parking lights that are coming on with the headlights. One filament can burn out and the other will still work.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
