Old 05-28-2008, 09:45 PM
blind60 blind60 is offline
Looking for a extra capacity transmission Pan
Does anybody have an idea where i could find a good extra capacity transmission pan thats not over priced? Im looking for one that will hold at least 4 extra quarts of fluid. I dont need any fancy finishes on the pan, just the ability to hold extra fluid. 92, K2500, 350, 4L80E
Thanks for your help!
Old 05-29-2008, 03:25 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Looking for a extra capacity transmission Pan
Summit has a wide selection. Why do you need the extra capacity?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 05-30-2008, 11:15 AM
This truck is one that I will be using to Plow snow. The extra capacity will help in keeping the tranny cool
Old 05-30-2008, 11:19 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
ever thought of putting a tranny cooler instead?
Old 05-30-2008, 03:45 PM
J-Ri's Avatar
That's the direction I was heading in, but didn't want to sound stupid if there was some other reason I couldn't think of. A cooler is probably cheaper, not much harder to install, and a better way to keep the fluid cool (I've seen regular trans pans that had dents in them, not to mention what might happen if it's 2-3" lower. If you decide to install the cooler instead, just be sure to route the fluid through the new cooler first, then back through the radiator cooler so the fluid stays the right temperature. Having it go through the new cooler second will cool it too much and possibly cause some slipping.
Old 06-07-2008, 05:20 PM
SLJ2137694 SLJ2137694 is offline
You are saying the transmission will slip in cold weather? I've driven many vehicles in freezing temps and never had a trans slip because the fluid was being over cooled let alone on a cold start. I'm confused by your comment?
Retired and Loving It!!! 33 years with General Motors Product Service Engineering. A.S.E. Certified. You can fix ignorant but stupid will be a real challenge!
