Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-28-2008, 09:23 PM
GreyGoose006 GreyGoose006 is offline
here goes nothing
problems so far:
right turn signal kills cruise control
no right turn signal
OD doesnt work because of a disconnected wire that was cut and blaah blaah blaah. (i need help with this one)
oil pressure guage is off. reads 35 psi at idle and goes up above 60 as soon as i start driving.
cruise control is harsh. when you bump it up or down it kinda jerks you around. maybe this is normal. idk.
needs an external transmission cooler. should be easy, but how?
rough idle and lower power until car warms up. id say about 2/3 of normal drivability and power.
coolant temp guage doesnt work. sits at 100.
horn is erratic. i guess a new button would solve that.
steering wheel is wrapped with some kind of getto rigged cover that needs to go. new steering wheel may be in order.
there is probably more, but i made the maiden voyage today after the tranny rebuild and this is what i found.
its an 85 iroc with a 350 dropped in
see my sig.
Old 05-29-2008, 04:27 PM
Re: here goes nothing
No replies?
c'mon, theres a lot there, surely someone can help me tackle a few of them...
Old 05-29-2008, 09:01 PM
Morley Morley is offline
Originally Posted by GreyGoose006
problems so far:
You have a short in the turnsignal stalk wiring most likely.
The speedometer in the 85's were mechanical, so a cut wire isn't going to affect the odometer. If the speedo functions then you need a new one with a working odometer.
Remove the oil pressure sender and temp. install a mechanical gauge to verify the reading is off. A cheap mechanical oil gauge can be had from any auto parts store. If the mechanical agrees that it is off, replace the sender with an AC Delco unit. The cheap-o ones from parts stores don't last if they work correctly at all.
Not normal. There should be some slack in the system where the cable hooks to the vacuum actuator, no slack is bad.
Buy one. Inside will be instructions, follow them.
Is it a TPI engine and if so, what are you using for an ECM and PROM chip. If you are using the 85's ECM (870) and chip, that is your problem. You need to upgrade to the 86-89 ECM (165) and a memcal (PROM chip package) to go with it. If you need the instructons on how to upgrade computers, let me know and I'll point you to the web pages for it.
Takethe wire off the sender and see what it does. If it maxes out, replace the sender.
see my sig.
Old 05-30-2008, 04:21 PM
by OD, i mean OVERDRIVE. sorry for the confusion
yep, i hooked it up myself and there is no slack. i will take it a link out one at a time till it feels right.
a bit sarcastic are we... its ok, i am too. i was looking more for what i need in the way of tools for cutting lines and stuff, and weather a simple cooler will suffice, or i should get one with a fan attached, also, how big is big enough, and is there any harm in going with the biggest one i can find...
well the previous owner put the engine in and "custom chip" is all i know about what is in it. apparently the engine builder took it for a drive, put a chip in it, took it for another drive, and made a few changes, but called it a day...
i LOVE info, so if you have any, i would appreciate it. i have no clue about car computers, but am trying to learn.
actually, i found that there was a wire going to the intake snorkel (MAF?) that was disconnected, and after connecting it, drivability improved tremendously. its still a bit off at first but not nearly as bad.
pardon my ignorance, but is this in the radiator? thermostat?
Old 05-30-2008, 06:23 PM
OK, you'll need to get a schematic or better yet, go to a junkyard and pull the connector out of a TPI car's transmission and cut the wires about a foot long. To wire yours up just match up the wire colors.
Not trying to be sarcastic, transmission coolers are just that simple to install. You look on the box and match up the GVW rating of the cooler to your car's GVW then maybe go one size larger (fans aren't needed unless you are going to be doing heavy towing). There is no cutting of lines to do. About all you'll need is a wrench to remove the line from the radiator and install their connector in its place. Then you'll need a screwdriver for the clamps. Don't go too big on the cooler, everything has an optimal operating temp.
So there is no telling what he did. The 85's 870 ECM isn't exactly a well supported ECM for tuning and has a lot of its parameters hard wired to the board, not on the chip.
Thermostat is under the waterneck on the intake manifuld, that is where the upper radiator hose connects.
Old 06-01-2008, 10:18 AM
ok. on my last car, there were hard lines going to the radiator for the transmission cooler that was built in. i assumed that i would have the same thing on this car and would have to cut them and re flare the ends or whatever.
http://store.summitracing.com/partde...5&autoview=sku
is this too big?
p.s.
just discovered that there is no actual transmission cooler built into the radiator.
so i will have to go bigger than normal.
Old 06-01-2008, 08:50 PM
is this too big?
p.s.
Umm, if you have an auto trans you better have a cooler in the radiator. You don't cut the lines for the transmission to install a cooler. Really, the instructions will have all of the info you should need.
Old 06-02-2008, 04:26 PM
well its an aftermarket radiator that the previous owner thought would be better i guess.
idk.
is that a good size?
thats all i want to know now.
if there is a formula to pick the size, that would be useful too.
Old 06-03-2008, 01:43 AM
idk.
So, I have to ask....If there is no trans cooler area on your current radiator...where do the transmission lines go to? If it is driven without any cooler for the trans fluid the transmission will soon be toast.
The cooler you have there is more for racing (note the 1/2" inlet/outlet). Whatyou need for street application is more like this http://store.summitracing.com/partde...5&autoview=sku
or this http://store.summitracing.com/partde...5&autoview=sku
Old 06-03-2008, 02:29 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
when i selected my tranny cooler size I just measured the A/C condenser that I had removed and bought whatever tranny cooler was closest. and the sender for the water temp gauges in on the intake manifold close to the front where the water neck is.
