Old 05-28-2008, 09:13 PM
xtrememeasures10 xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
Possible Fuel Sending Unit?
My buddy has a 2000 1500 silverado and when he turns the key to start the truck it does nothing the first time. Then he turns it again and it fires right up. It runs fine after that. He thinks its the fuel sending unit. Before we go pulling the pump/fuel sending unit assy i wanted to get some second opinions.
Old 05-29-2008, 08:15 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Possible Fuel Sending Unit?
In do nothing does the engine crank over or just not crank or crank over and not start?
The fuel sending unit will not keep it from starting or running.
What makes you think the fuel sending unit is causing problem?
Is the fuel sending not working all time or what is up on that end?
MT
Old 05-29-2008, 09:07 AM
wafrederick wafrederick is offline
Banned
Do a fuel pressure test first and look up the specs.If it is lower than specs,bad fuel pump.Go with a Delphi pump,Carquest auto parts store or the dealer.CarQuest did switch to Delphi and kicked Airtex to the curb for their fuel pump supplier.Since CarQuest switched to Delphi,no more problems with their fuel pumps.
Old 06-09-2008, 08:05 PM
Yeah i just wanted to check and make sure im not an idiot. Its been like 3 years since i worked in a auto shop. I didnt think it could be that unless there is something in the fuel sending unit when the pump is starting to go bad that tells the starter not to engage. I havent actually driven it before. But if i recall correctly when he turns the key the first time it doesnt do anything, no engine crank, no nothing, the only thing that changes is the chime scilences, then the second crank it starts right up. I told him i think its something else, maybe ignition related. But he is one of those know it all types of people that just look at you and say no i know this is it with no experience in anything. It infuriates me we always get into fights about cars and problems with them. He thinks he knows best and more than me even though im ase certified and have my airframe and powerplant license, and all he has ever been is a carpenter.
Old 06-10-2008, 09:26 AM
Bob B Bob B is offline
The fuel pump can't tell the starter not to go.
I feel the problem is likely in the battery cables being corroded a bit and or not tight usually at the battery
Bob B
Old 06-10-2008, 02:53 PM
MT-2500's Avatar
AF - Advisor
Well in them cases I just hand them a wrench and tell them to have at it.
But good luck on it and with him.
MT
MT
Old 06-15-2008, 05:11 PM
MT
Lol Yeah thats pretty much what im like. He just wants to try n drag me into it.
Bob B
Yeah loose ground or bad wires sound more likely to me too.
