93 mazda with drivers side front wheel squeak(??)
I have a 93 protoge with an incurable sqeak in the right, front wheel. Replaced axel, strut, break pads, disc, and calliper. Any other suggestions would be appreciated.
Re: 93 mazda with drivers side front wheel squeak(??)
Maybe anti-sway bar link.
Clifton |
Jack it up and see if you get a squeak when you rotate the tire. Turn the steering back and forth and listen. If you are using a hydrolic jack, see if it squeaks when you lower it quickly.
hi, are u sure its the wheel, because i have 323 imola and had a similar prob on passenger side, i took it to the garage and they rekon its the clutch thats making the squeak, does it squeak when u put ur foot down and take it off quicky whilst drivin, or sit wiv the handbrake on and come off the clutch but dont let it stall, do that a few times staright after each time, if it squeaks its ur clutch, but u cant get rid of the noise if it is, unless u change clutch.
I have a 95 protege front left wheel sqeaking its my wheel bearing. That's the only part you didn't replace as well. That's most likely your problem.
