Old 05-28-2008, 08:31 PM
aviacionlight aviacionlight is offline
Chevy 6.5 turbo diesel Truck wont start
Hi.
My Chevy 6.5 turbo diesel truck was working fine but today was a hard day because does not wont to start, i do almost everything indicated on the owners manual but nothing happens.
There is some diferent, i can not hear a loud noise (click) that usually does it wen i turn the key on, would be the glow plug relay click on & off?
Any ideas?
Thanks
Old 05-29-2008, 03:30 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Chevy 6.5 turbo diesel Truck wont start
I wouldn't think being in Mexico that you'd need the glow plugs at all, they're really only needed in colder climates (but the click could be something else that you need). I'd start by checking all the fuses, maybe someone with diesel experience can advise you on checking fuel pressure. All I know is the pressure is WAY over what gasoline guages go to.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
