Old 05-28-2008, 08:11 PM
Turbokid15's Avatar
Turbokid15 Turbokid15 is offline
01 AC question
Ok here is the situation. The pump locked up so it was replace with a new one. I filled it up with freon but it doesn't seem to be getting any colder what is the secret.
The truck
07 F-350 CC Dually Stroked
Old 05-28-2008, 08:23 PM
Hungrycat7's Avatar
Hungrycat7 Hungrycat7 is offline
Re: 01 AC question
Might need to check the entire system for leaks
Old 05-28-2008, 09:11 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 01 AC question
Did you really use Freon (R-12) or R-134a? Does the compressor clutch engage and spin the compressor? If so, how long does the compressor stay engaged?
-Rod
Old 05-29-2008, 05:52 AM
Turbokid15's Avatar
Re: 01 AC question
We used R-134a "Big Chill" and you can hear the compressor come on and it will run without cycling on and off.
The truck
Old 05-29-2008, 06:44 AM
shorod's Avatar
SHO No Mo
Re: 01 AC question
Did you pull a vacuum on the system to get all moisture out (and verify no leaks) prior to filling with the R-134a? I'm not sure if the compressor would stay engaged if there is moisture in the system, I suspect it would.
You may also want to check proper operation of the blend door, maybe your blend door is stuck blending too much air through the heater core.
-Rod
Old 05-29-2008, 03:53 PM
Turbokid15's Avatar
Re: 01 AC question
How would I go about putting a vacumm on it?
The truck
Old 05-29-2008, 08:17 PM
reekor reekor is offline
Re: 01 AC question
That's because you didn't replace the dryer and orface tube. When the compressor locks up it tends to send metal shavings into the system then plug the orface tube. With that said you also voided the warranty on your new compressor by not change these items.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 05-31-2008, 04:05 PM
Turbokid15's Avatar
Re: 01 AC question
Little Update. The compressor will come on then go off constantly. What is the deal. The compressor is constantly cycling.
The truck
Old 05-31-2008, 05:02 PM
Re: 01 AC question
What is the pressure on the low side is it normal????? If it is then you more then likely have higher then normal pressure on the high side that might be cycling the compressor due to what I said above.
