Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 05-28-2008, 05:50 PM
Broken-wrench Broken-wrench is offline
E36 Brakes...
I just installed new pads & rotors on my 1994 E36. I used upgraded Cool Carbon pads with German made gas slotted rotors. After bedding in the pads correctly, the car has become uncomfortable to drive as in no rear suspension! It seems as if the rear brakes have pre loaded the read end and it will hop around like a low rider at times. I took the rear brakes back apart & re lubed all contact points with that trick CRC caliper grease. Helped a little. Any ideas except putting a set on Mintex rear pade on to see what happens? I used a pressure brake bleader to blead all the brakes. No ABS lite~ thinking of pulling the fuse on that just to see what happens. Any ideas on how to rid myself of the low rider hop?
Old 06-16-2008, 01:27 AM
OKCSuburban OKCSuburban is offline
Re: E36 Brakes...
Other factors?
Shocks? Bushings? Calipers sticking?
How many miles,
2000 Suburban, 4wd, LT, 143k. (Sold and missed)
BMW 318i Convertible, 996 Porsche, BMW X5, Silverado (sold) Honda Ridgeline.
Old 06-30-2008, 04:20 PM
Re: E36 Brakes...
Hey Guys, I re-bled the brakes using a pressure bleeder. Had to crank it up to 30 psi to get the ABS to bleed. That solved it!
Old 08-30-2008, 12:22 PM
titaniumbullet titaniumbullet is offline
Re: E36 Brakes...
Nice!
I Love my BMW KIT
Old 08-31-2008, 07:34 AM
Re: E36 Brakes...
Thanks for the update. Good info to know. One of the cars in my household has an ABS light showing.
