Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 05-28-2008, 05:40 PM
bostonjas bostonjas is offline
Send a message via AIM to bostonjas
Car lock doesnt chirp anymore, HELP!
So since december when i press the buttom to lock the car it doesnt make any noise , it doesnt chirp. So ive taken it to a few places and they keep telling me to take it back to the dealer. I did today and they told me its gonna cost $100 to hook it up to a machine and it will tell me where the locking mechinism is found in the car and can be fixed.....
does anyone know how i can fix this or where it is in the car
i know im gonna pay 100$ and there gonna tell me they dont know..
HELP!
ohh yea its a 2006
Old 05-29-2008, 03:12 PM
sedmonds sedmonds is offline
Re: Car lock doesnt chirp anymore, HELP!
First question is, does it still work ? If you click lock on the remote does it lock the doors as normal and if you try to reach in an open window and unlock to open the door does the alarm go off ? If everything works but the chirp sound, does the horn honk okay ? I think it uses the same speaker/blowhorn under the hood.
Old 05-31-2008, 08:53 PM
it still locks but i have to sit there and watch it to make sure. It just sucks cuz i cant beep it to lock it or find my car. the horn works fine
since chevy wants to charge me 100$ to maybe find out im thinking maybe take it to a electronic place, a place that does auto car starts and extra goods
any ideas?
Old 06-05-2008, 01:41 AM
genefitz genefitz is offline
Okay, first off, what year is your Aveo?
Second, if your horn does work, do you see the parking lights flash once when you lock, twice when you unlock?
Third, does the alarm work? (try opening your trunk while the doors are locked)
My 08 Aveo only honks once when I lock (arm the alarm) the doors. It does not honk when I unlock the doors.
All that said. If your car is less than 3 years old, or has less that 36,000 miles, and you have not fooled with the alarm system (added or taken from), the car should still be under the original bumper to bumper. They shouldn't charge you a penny to check out the alarm.
If the horn works, at las I recall, ALL Aveo alarm systems run through the horn, it should only give a short honk to let you know it is armed. And your lights should blink once to tell you it is armed, and twice to tell you it is disarmed. If neither your horn or lights are letting you know that your system is armed or disarmed, then you should check out the power to your alarm module, most likely the alarm is not working. This could be a fuse or an open in the power or ground.
If your alarm IS working, and your lights are flashing, then you will most likely have an alarm module failure. If your lights are blinking with no horn alarm, and the alarm is working but only showing flashing lights, and no audible horn alarm, then it would be an open in the out-leads from the alarm module to your horn (note: the horn may still work, just the connection from the horn to the alarm module itself may be broken.)
Last case, if your car is not under warranty, if you try all these ideas and come to no resolution, spend the $100 to get it checked. I would anyway. If the dealership does the repair, you get some guarantee on the work.
Just a thought (or 12)
Old 06-06-2008, 10:29 PM
allene1965 allene1965 is offline
Be thankful that it locks and stays locked. I have a 2007 and sometimes when I lock it it will unlock it's self or if it's unlocked it will lock it's self so I don't dare leave the keys in the car for a minute.
