Go Back   Automotive Forums Car Chat > Pontiac > Aztek
Old 05-28-2008, 10:08 AM
artnathan artnathan is offline
a lot of issues Help
HI i have some problems with my aztek
  • a noise in the front right wheel when i dreiving it slowly
  • the brake pedal modulates and a noise is present when this happen
  • the messages panel shows a TC alert and the abs ligth comes on
  • the check engine light is on and flashing when a try to run it faster
any ideas for this issues?
thanks
Old 06-02-2008, 07:52 AM
Chameleon-kat's Avatar
Chameleon-kat Chameleon-kat is offline
Send a message via AIM to Chameleon-kat Send a message via Yahoo to Chameleon-kat
Re: a lot of issues Help
Grinding/ metal on metal noise on front wheel may be wheel bearing, more noticable driving slow and/or when turning one way or another.
TC and ABS light indicate problem with wheel sensor, first thing dealer would do after putting magic puter thing on to find which wheel it is complaining about would most likley replace wheel bearing/hub assembly. In many cases though as our vehicles age is either corrosion on connector or broken wire to sensor on hub assembly (could be wiring thing elsewhere though).
Blinking CE should set code that could be read (for free) at some auto parts places (such as auto-zone) and would point to something that needs replacement.
Old 06-02-2008, 08:34 AM
i was reading in some owners books, and says that maybe this happen when you have a multiple misfire, i think that this could be a malfunction fuel pump, becuase sometimes i ear a noise from the fuel tank.
thanks for you help y will check the bearing
