Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 05-28-2008, 02:09 AM
Amari1210 Amari1210 is offline
Programming a 2000 Chrysler Sebring Fob
How do I program my Chrysler Sebring Convertible 2000 fob?
Old 05-28-2008, 08:22 PM
wafrederick wafrederick is offline
Banned
Re: Programming a 2000 Chrysler Sebring Fob
Take it to the dealer.It has to be programed with Chrysler's factory scan tool,DRB III
Old 05-30-2008, 04:08 AM
I was trying to avoid the $35 they will charge me. Thanks! I appreciate the response. I was hoping I could do it myself. :-)
Old 06-23-2008, 09:14 PM
bearcatdon bearcatdon is offline
Look in the owners manual. That's where I found the sequence for my 2003. You do need a working FOB to initiate the program mode. If you don't, the dealer is the only one that can help you. Here is the 2003 method.
1) Turn ignition switch to the ON/RUN position
2) Using a currently programmed transmitter, press the Unlock button. Continue holding the Unlock button for 4-10 seconds, then press and hold the Panic button for at least 1 second. Release both buttons simultaneously. You will hear a chime to signal that you can proceed with programming the new transmitter.
3) Press and release the Lock and Unlock buttons simultaneously, followed by a press and release of ANY button on each new transmitter to be programmed as well as the original transmitter. You will hear a chime when a transmitter has been successfully programmed. You will have 30 seconds to finish programming all new transmitters. A chime will sound when the 30 seconds is over or the ignition switch is turned to the LOCK position.
