Old 05-27-2008, 09:04 PM
Cbierniat's Avatar
Cbierniat Cbierniat is offline
2000 ABS light SES light
Im here posting for my buddy again... every so often his ABS light will come on and so will his SES simultaneously and stay on until the car is shut off. I told him to take his car to autozone to get the quick cheap scan for the codes on the SES but the ABS Im not sure.. is that sensor related? Any experience this before??
Old 05-27-2008, 10:23 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 2000 ABS light SES light
yes you would need an ABS capable scan tool and most autozones dont use those, some advance autos do though none around where I live.
1999 Grand Am SS 3.4 OHV
Old 05-29-2008, 03:57 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Yeah, most of those scanners only make it easier for them to sell parts, and a lot of the time the person working there doesn't know how to use them or what a code means, even if the scan tool is capable.
Make sure the tire pressures are even, if one or more are low it can cause the wheel speed to read low and turn on the light.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 06-01-2008, 12:35 AM
homeskillit37 homeskillit37 is offline
if the trac off light comes on too it could just be a loose connection to the speed sensor in the wheel hubs. First thing to try is clean up the connections and make sure they are seating good. If they are loose when you hit a bump all the lights will come on until you shut the car off. I have to do mine every 6 months or so because the wires get pulled loose.
Old 06-01-2008, 11:14 AM
i've never had my lights come on from a low tire and I've had a few flats over the years.
Those wires are a problem, a little short IMO.
Just another way GM was pinching pennies.
