Old 05-27-2008, 07:09 PM
92-silverado7.4's Avatar
92-silverado7.4 92-silverado7.4 is offline
ToeKnee
sub polarity question
I have a 12 alpine type r in a ported box. Today I flipped it over, meaning the cone is facing the inside of the box and the basket is outside the box (because I tought it looked cool). Well the bass hits alot lower like that. My question is, Would my problem be fixed if I connect it backwards too?....or would that just burn the crap out of my stuff?
Ford F-250 single cab bangin' How do I change my username?
Old 05-27-2008, 09:13 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: sub polarity question
Inverting the sub also makes the enclosure a bit larger since you remove the displacement of the basket, magnet etc. As far as switching polarity, ive never damaged a sub doing that. In fact i have run a few systems with dual woofers with one sub running normal and the other reverse, something to do with the phase. Ive never gotten into it as i havent really had resons to, im sure paul knows more about it than i do. You can try it its a 1 in a million chance of damaging it. Was the enclosure made for the sub or is a prefab.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 05-28-2008, 07:13 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
ported boxes are more sensitive to volume, and inverting the sub increases the volume a little (as stated above). The phase means nothing as far as volume goes, especially if you only have one sub. Sometimes it actually sounds better, blends better with the midbass or midrange when the sub is connected backwards.
Old 05-28-2008, 08:03 PM
ToeKnee
I'll give it a try right now, see what happens......thanx guys!
