Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 05-27-2008, 12:10 PM
Another_Drummer Another_Drummer is offline
Check Engine Light - Finally Got The Codes
Well, I finally found time to go to AutoZone to get the codes on my car checked out. These are the two codes I got:
1 - P0405
2 - P0141
The first one was EGR issues, and the 2nd was the O2 sensor (bank 1 sensor 2). I went with the first code to get it checked out and give it a shot. I took off the EGR and cleaned it with carburetor cleaner just to make sure and put it back on....engine light was still on. So I went and coughed up $170 for a new one. Popped it on...and the engine light went out for a while....then it came back on a few miles later. Now I have to clean the O2 sensor or replace it to see what happens next. I'll have to find out where it is located and get to that next.
I'm sure this is still much cheaper than a shop doing it..... At least I hope so.
Old 05-30-2008, 09:18 AM
LEM LEM is offline
Re: Check Engine Light - Finally Got The Codes
You may also need to clean out the EGR tube that's accessed by removing the throttle body; it will get plugged up pretty badly over time and cause an EGR code. If you check the FAQs for 98+ Troopers you should find something about the EGR; there's a pretty good write-up on how to clean it and the EGR tube.
Good luck!
Old 05-30-2008, 09:26 AM
Well I'll try that as well. I couldn't find it online. Anyone have an idea as to how easy this is done?
