Old 05-27-2008, 11:04 AM
302Z28 302Z28 is offline
Fuel pressure
My '97 Cav 2.2 is in a shop having a stumbling problem checked. I received a call stating that the fuel pressure was down to 59 PSI. Apparently, it shoould be around 70 PSI. Although I am not familiar with injection systems, it seems to me that everything should still function properly at 59 PSI.
Could the 11 PSI drop in pressure cause a stumble from idle? The car runs great at cruise speeds and part throttle.
Are there any factory specs on fuel pressure range?
Thanks,
Old 05-27-2008, 09:11 PM
Helmuth48's Avatar
Helmuth48 Helmuth48 is offline
Thumbs up Re: Fuel pressure
That seem very high.....per the manual. Key on, engine not running is 41 -47 psi
You may have a defective pressure regulator or a pinched or clogged fuel return line.
JzJzz ...and the man from down under....Cheer mate !!!
