Old 05-27-2008, 11:53 AM
CifeNet's Avatar
CifeNet CifeNet is offline
How to remove the factory paint on 1/12 Revell F2002 kit?
I would like to get some advise as to what would be a good approach to remove the factory paint?
They look quite thick, I was thinking either I deep them in a mild paint thinner and give a nice bath to remove the paint.
Or start sanding away the outter layer of the paint and give a nice primer coat and polish out the surface.
Does anyone have an idea as to what would be a good way to remove the paint? And "secret" chemical product I should try?... Maybe sanding is the best way?...
Thanks!
-- CifeNet
Old 05-27-2008, 12:54 PM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
Re: How to remove the factory paint on 1/12 Revell F2002 kit?
Is it a plastic or metal kit? If it is plastic, thinner is your worst option. I use DOT 3 brake fluid when I need to strip paint
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 05-27-2008, 01:26 PM
ferrari2k ferrari2k is offline
Send a message via ICQ to ferrari2k
That kit is a plastic kit. I left the colour as it was, looks nice
Old 05-27-2008, 01:35 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Have you read the FAQs by any chance?
Definitely do not use paint thinner. Skip the brake fluid also, it too can destroy plastic.
If you don't know what the paint is, I'd start with 99% isopropyl alcohol. You could also try a cleaner/degreaser like CSC, Purple Power, or Simple Green.
PHOTOBUCKET SUCKS
Old 05-27-2008, 01:53 PM
CifeNet's Avatar
Thanks for the tip. Will try several methods discussed here. I usually use CSC and isopropyl alcohol to remove chrome and the usual paints, but I heard this Revell kit's paint is nasty.
That was why I was asking this question regarding this kit hoping someone who actually successfully removed the paint from this kit.
-- CifeNet
Old 05-27-2008, 02:03 PM
wouter1981 wouter1981 is offline
well Isopropanol will remove any type of paint i know, but sometimes it can take a lot of time. The paint on the wheels of my caterham took 1.5 years to get the paint off!! But there was absolutly no damage on the plastic. So this is probably the safest way.
Old 05-27-2008, 05:18 PM
jaykay640 jaykay640 is offline
I got the paint off the kit with brake fluid. No harm to the plastic. I dipped the pieces in it for a couple of hours and then wiped the paint off with a brush. I'm in Germany so i can't recommend a brand in the U.S. but the bottle says it's DOT4 and complies with US-Spec FMVSS Nr.116 DOT and SAE Spec J1703/ISO4925.
Hope that helps:-)
Old 05-27-2008, 05:21 PM
sitwhiteysit sitwhiteysit is offline
I used 91% isopropyl alcohol in a sealed tupperware container on mine and it came off very easily.
Old 06-24-2008, 01:04 AM
CifeNet's Avatar
I thought I should post the result on this topic-
- The Castrol Super Clean didn't work
- 99% Isopropyl alcohol didn't work
Then I tried Polly S East Lift Off. Sinked for about 3 hours and the paints came off quite nicely.
-- CifeNet
Old 06-24-2008, 06:22 AM
sjelic's Avatar
sjelic sjelic is offline
I hope I will see a WIP some time soon, it should be a stunner. Did you get the SMS kit for it?
Sasa Jelic
SCALEMAKERS
Old 06-24-2008, 05:44 PM
Yep...good job...now where is the WIP!? :-)
