Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Old 05-26-2008, 10:56 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Fuel pump blues
Hey guys. I found out my spare pump is a 255 HP which is nice since I'll be running E85 and I can use all the flow I can get. Well, I went to work to get the old one out and sure as shit the part of the line where the flexible part of the feed line connects to the hard line coming out of the tank was corroded as hell. While trying to get it off, I managed to get a pin prick hole in that hard part of the line right near the base of the cover part. Get what I am saying? Well the 255 HP is still in the whole assembly from the donor car, which also had the hard line out of the cover snap but it was farther up the line. So I was thinking I would cut the hard line on the car right above where the pin prick hole is, straighten the end of the line out, straighten the end of the hard line on the other pump assembly, and make a band-aid of sorts with a piece of fuel line that would go over both of the ends of the line, then I would use small hose clamps to keep the outer line from leaking. Does that make sense? Would it work? I really dont want to have to buy a new SS feed line right now, that would really put a cramp in my style. Any info would help a ton thanks ya'll.
EDIT: So I feel like an idiot. I have read just about all of the articles on tuners that relate to engine an performance stuff, but I have not read this one. I read it and it seems like a solid fix, but if the way I asked about would work, then I would rather do that. So if you think my way will work please speak up, otherwise I'll just follow the tech article.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-27-2008, 06:23 AM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Fuel pump blues
I think the fix in that link is pretty solid. I'd worry about your way leaking around the outside edge.
Old 05-27-2008, 05:46 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Fuel pump blues
I would think you should be fine. Whats it going to hurt if it leaks a little bit. It wont cost much or anything to do so if it doesn't fix it then you just wasted some time. Its not like you would have spent a lot of money on a fix for it and it didn't work.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 05-27-2008, 06:56 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Fuel pump blues
Worth a shot, but I would still feel better with a 10 dollar bulkhead fitting in there with some socketless/twistlock hose. You can try that trick in the article, and if you're not happy with the result or it leaks too much through that grommet at 4 bucks a gallon, you can drill it out for a bulk head fitting and go that route.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-27-2008, 10:43 PM
Thor06's Avatar
Jizzed In My Pants
Re: Fuel pump blues
Yeah, I like that idea too. I agree, I was a bit worried about the grommet. I think I'll just see how I'm feeling once I get to that point, the last tank cover nut is not wanting to come off. I'm fed up with it, I am just going to take the dremmel to it tomorrow. Anyway, I guess I do think I will give my way a try, but I am going to keep an eye on it for sure.
I think I'll use like a 3" section of hose to go over the metal lines, with the metal lines like a half inch apart. I'll probably use two small hose clamps on each side just to be sure, that way I wont feel like I really have to wank each one down (potentially reducing the diameter of the metal line) to get it to seal. I also think I might use some silicone or something around the ends of the hose just for a little extra sealing. I'll have it open in like two weeks or so anyway to rewire the fuel pump, so I can double check it.
Old 05-27-2008, 11:18 PM
AF - Advisor
Re: Fuel pump blues
All you'll need to get the hose clamps to work is to give the ends of a metal line a slight bead. That will do more than 10 lbs of rtv.
Kevin Jewer
Old 06-07-2008, 05:34 PM
Thor06's Avatar
Jizzed In My Pants
Re: Fuel pump blues
Ok, so I CANNOT get the last bolt off my fuel pump cover. I've tried vice grips, minor filing, even JB welding the socket to the nut. Nothing has worked!! Anyone have any ideas? I'm about 4 seconds from just fuckin turning the tin snips on it, but I am worried about getting shit in the tank. Help!
Old 06-07-2008, 09:36 PM
AF - Advisor
Re: Fuel pump blues
Cut a slot in the nut and ship it. If you only lose one stud in this process you're doing better than most people.
Kevin Jewer
Old 06-07-2008, 10:06 PM
Thor06's Avatar
Jizzed In My Pants
Re: Fuel pump blues
Ok. I'll do it with my dremel and the little ass pointy carbine bit I have for it. You dont think I have to worry about igniting the fuel fumes do I?
Old 06-08-2008, 10:00 AM
AF - Advisor
Re: Fuel pump blues
Well, you should always worry about those kinds of things, safety first.
Kevin Jewer
