Go Back   Automotive Forums Car Chat > Buick > Century
Old 05-26-2008, 07:55 PM
69lindsey 69lindsey is offline
99 Century hard to start
I have a 99 Buick Century that turns over for 5-10 seconds before starting. I have changed plugs, wires and fuel filter. The fuel pressure is 44 lbs when switch is turned on and pump is running. When pump stops running pressure drops to 40 then slowly drops from there. Also when the cap on the rail was taken off to check pressure it was wet with fuel. Where should I start? fuel pressure regulator? Fuel Pump? or something else?
I have used this site in the past for lots of usful info finally joined.
Old 05-26-2008, 09:38 PM
inafogg inafogg is offline
Re: 99 Century hard to start
if ur talking about fuel press regulator being wet or vacuum line then reg is bad
Old 05-27-2008, 11:53 AM
The regulator was not wet. The inside of the cap on the end of fuel rail where pressure is checked was wet.
Old 05-27-2008, 11:57 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
That fitting shouldn't be wet except for right after you check fuel pressure. If it is wet, it is leaking and could be the source of the pressure bleed-off causing the initial long crank time.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-27-2008, 08:31 PM
I changed the fuel pressure regulator. Checked pressure valve again not leaking. Pressure drops 2 lbs per minute after switch is turned off.
Switch on pump running 44 lbs
pump off 40 lbs
car running 38 lbs
What next?
Old 05-28-2008, 05:57 AM
richtazz's Avatar
Your fuel pressure readings are a little on the low side. Try priming the fuel pump by turning the key on for 3-4 seconds then back off a few times without attempting to start. Then try to start. If it starts right up then, you have a fuel pump going bad.
Old 05-29-2008, 03:36 PM
I changed the fuel pump. No change in starting. Once the car is started I can shut it off and it will start just fine its after it sits for a while that it is hard to start.
Could it be the injectors?
I also read that it might be something to do with oil pressure is this possible?
Old 05-31-2008, 11:47 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Negative. Not applicable to the 3100 VIN "M" engine. The oil pressure sending unit is just a sending unit and not a combination switch that affects starting nor provides alternate power to the fuel pump.
Leaking injector(s) is possible but you'll need to run a leak down test.
Timeslip 08/12/06
AF Community Guidelines
Old 06-02-2008, 07:09 PM
This car is one of my wife's mail cars after she drove it saturday she said she smelled gas all day. I search for front to back looking for a leak. I finally decided it was coming from the fuel pump. I took it out reinstalled with some sealant on the o ring. Problem solved!
