Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-26-2008, 07:38 PM
rickyrickster25's Avatar
rickyrickster25 rickyrickster25 is offline
Random Idea... Would it work?
So i was looking on ebay the other day and a came across a pretty nice looking used FMIC and it got me wondering, instead of a CAI, what if you rigged up a turbo-less FMIC system in a NT car... Would it gain you anything reasonable?
I mean if you look at it it seems like it would be a good idea, but would the FMIC slow down the flow of air to an NT car? Or would it actually cool the air better then a CAI? Is this just a dumbass idea? lol
What do you guys think? I think it would be a fun project and its not something you see everyday which is why i would want to do it...
97' Eclipse RS 5 Speed 420A
Under The Hood:
Bomz UDP, Custom CAI, NGK Plugs, Mopar Wires
Interior:
Blue Glow Dash Guages & HVAC Controls, Neon Accents, Custom Dash Work\Paint, Alpine Type-R/JL Audio System, Custom Trunk Layout
*GOAL* - Prove Him Wrong
Originally Posted by UnderEstimate Me
I doubt bolt-ons will get you to 160hp on the 420a. Unless you have some dyno sheets Im calling bs.
Old 05-26-2008, 08:12 PM
steviek's Avatar
steviek steviek is offline
Re: Random Idea... Would it work?
throttle response would go down peak power would go slightly up
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 05-26-2008, 09:10 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
I think you will lose performance on the whole.
I came up with the idea of the turboless FMIC along time ago. I was going to do it when I had my FMIC laying around before I put the turbo on, but I didnt get around to it before I went ahead and turboed it.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 05-26-2008, 09:45 PM
Yea i found a forum about it but all anyone did was bitch at eachothers input so i figured i would try it here, but the throttle response was brought up. Is there any way to mess with the system to make it work better? I just like to fabricate up crazy shit and i think it could be a fun idea to work with, plus a FMIC looks sexy on a 2g but i wouldn't want to have it just sitting there...
Under The Hood:
Interior:
Old 05-26-2008, 10:08 PM
steviek's Avatar
Why would he lose power on the whole? Eventually the cold air will reach the intake in a cooler form then it would with a traditional style intake. There is something to be said about pressure and velocity and all that stuff but he never specified which type of routing and which size pipes. I believe that if its done properly to his setup there is at least a couple hp's to be gained from it. WOuld it be worth it in dollars/hp no chance but what would cause the overall hp loss?
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 05-26-2008, 10:33 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
There would be no performance gain, infact it will be a negative. The job of the intercooler is to cool the hot air from the turbo as close to ambient as it can before its consumed by the car. On a NT car, since the air is in the intercooler is going to be negligibly different than the ambient air temp, the opportunity for performance is not there and thus the intercooler is nothing more than a giant blockage in the intake tract.
Its a pretty simple thermodynamic problem, a body A at temperature X cannot cool a body B to a temperature <X with out work being done on the system. Since no work is done, even at 100% efficiency (intercoolers are not, I believe its something more like 75%-80%?) the lowest possible temperature of body B is X. In other words, the lowest possible temp assuming 100% efficiency of the intercooler is the ambient temp. In the NT system, since the ambient temp is essentially equal to the intake temp, the intercooler is doing nothing.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-26-2008, 10:37 PM
kjewer1 kjewer1 is offline
AF - Advisor
True story. The rate at which the air changes temperature varies directly as the difference in temp between the charge air and the ambient air/IC. With only a ~20 degree difference the drop would be minimal. The lower density of the charge air wouldn't help either. The weight of the IC would negate any minor gains, which would probably too small to measure anyway. A CAI is much lighter and more cost effective. Even still, every 11 degrees drop is only good for 1% gain IIRC, which on a low power non turbo car just doesn't add up to an appreciable gain in most cases. For example, at 200 hp, a 10 degree drop is good for ~2 hp, etc.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-27-2008, 04:45 PM
I understand what you are saying, but wouldnt the fact that the wind was blowing on the intercooler have some effect on the temp change, or is that just one of those things that isnt the way it seems?
Under The Hood:
Interior:
Old 05-27-2008, 04:51 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Are you figuring having the filter on the end of the IC then the other end going to the intake? You will have no gains with that because the air is blowing into the filter and going through the core. The air temp at the filter and the core is same temp (ideally if filter is where a CAI would be). The air since it's not moving at a fast rate, just sits and takes it time going through the core and will actually warm up (depending on air temp).
Basically, no.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 05-27-2008, 05:42 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Everyone is correct. It will not improve performance at all.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 05-27-2008, 07:00 PM
Alright well thanks for your input guys.
Under The Hood:
Interior:
Old 06-21-2008, 01:02 AM
talon sleeper talon sleeper is offline
speaking about random ideas. does anyone know if it would be reasonable to swap a 1997 talon esi motor out with a mitsubishi evo motor. just an idea that i thought would be cool to really have people guessing if that was really an esi that blew their doors off.
Old 06-21-2008, 05:34 AM
Thor06's Avatar
Jizzed In My Pants
Yeah dude, its been done before.
Old 06-21-2008, 01:49 PM
Alright i was just wondering about the transmission and how all that shit would work with swaping those engines. Like wether the transmission in it now would work or if i would need to use one from an evo too or not. Haha because i have no idea with this stuff i am just starting to get into it.
Old 06-21-2008, 05:52 PM
david-b's Avatar
Dave is THAT guy
If you have no idea on this stuff... don't even try. Everything has to be replaced and used from the EVO
75 Monte Carlo
