Old 05-26-2008, 09:13 AM
JTG3295 JTG3295 is offline
Steering Fluid Leak
Hello everyone I`m new to this site and have a question about my 2001 Pontiac Grand Am Gt. I just changed the brakes and rotors all around and during that i turned the wheels without the engine running and notice that it spit out some steering fluid from the rack/pinion. With the engine running it & turning the wheels it does not leak any fluid at all. It`s not leaking with the engine off either.. Is that normal??
Old 05-27-2008, 02:27 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Steering Fluid Leak
Welcome to AF.
No, leaks are not normal, thier shouldn't be any leaking of any fluids.
Could be a hose, could be a seal in the rack.
Wont realy know untill you check under the car.
1999 Grand Am SS 3.4 OHV
Old 05-29-2008, 04:05 PM
J-Ri's Avatar
J-Ri J-Ri is offline
I have never seen that on a GM, Fords and Chryslers will leak from the reservoir cap of you force the steering wheel too hard with the engine off.
Are you sure it was P/S fluid? Is it possible you pressed the pistons back in on the calipers, causing the master cylinder reservoir to overflow onto the rack area? That'll happen if you've ever topped off the reservoir/
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
