Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-26-2008, 12:17 AM
Fit4Demolition Fit4Demolition is offline
Send a message via AIM to Fit4Demolition
failing inspection due to nitrogen emissions
1984 Pontiac Trans Am 305
i heard it is an easy fix, like a messed up egr valve or something, i didnt exactly hear the guy that was telling me what was up when his car had the same problem. but anyway, any idea what i need to do to get this fixed so i can finally get my car passed.
and also i need to fix the parking brake. any tips?
Old 05-26-2008, 08:03 AM
chevyrulespops's Avatar
chevyrulespops chevyrulespops is offline
Re: failing inspection due to nitrogen emissions
Increased nitrogen is a result of a defective egr or a component in the system such a thermostatic control device or ported vacuum device or a faulty vacum hose leading to the EGR. You could test the egr with a vacuum pump to see if it opens. I would also inspect the chamber underneath for any kind of buildup or restriction. I would replace all of the components in the system.
