Old 05-25-2008, 09:46 PM
Phoenix69 Phoenix69 is offline
grinding noise while driving
Hey guys,
A while ago I noticed that if my wheel were turned to the left a little bit even from straight I would hear a grinding noise. The noise pulses depending on the speed I am going, and the rotation speed of the tires. The faster I go the higher frequency of the cha cha cha noise. Any ideas what could be causing it? Thanks.
Old 05-25-2008, 10:20 PM
inafogg inafogg is offline
Re: grinding noise while driving
hello,brake rotor warped brake indicator???the way u discribe ur not turning very far(a little) right???maybe even a tire or bearing??
Old 05-26-2008, 11:12 AM
Can a rotor that needs griding down cause this? How bad is it to let it go for a long period of time unfixed?
Old 05-26-2008, 02:08 PM
sure a worped rotor could & letting them go until the pads wear down would be ok
Old 05-26-2008, 07:00 PM
what would cause a warped rotor? how could you prevent it from happening again if it is the case? what are the odds of it being the CV joint?
Old 05-26-2008, 08:17 PM
Scotty89's Avatar
Scotty89 Scotty89 is offline
The most common cause of a warped rotor in my area is over torqued lugnuts. From useing an impact wrench and over torqueing the lugnuts. Getting the rotors really hot can warpe them too.
