Old 03-05-2003, 10:19 PM
Josh95cx Josh95cx is offline
Shaving moldings
I was curious how to go about shaving the moldings on the side. What do you use to do it? Weld over it or body filler? thanx
Old 03-05-2003, 10:42 PM
ice_rr's Avatar
ice_rr ice_rr is offline
Send a message via ICQ to ice_rr Send a message via AIM to ice_rr Send a message via MSN to ice_rr Send a message via Yahoo to ice_rr
yeah you have to use a body filler than you have to sand it out! you have to put lots of time in it! cuz you want to be smooth and even! dont forget to put primer after for the paint!
Old 03-06-2003, 04:16 AM
redmanjd redmanjd is offline
you use primer before you paint. primer over the filler then seal the primer then paint
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 03-06-2003, 07:53 AM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
yeah he was saying to use primer after the sanding and everything for painting, so sand, primer, paint... he had it right hte first time, just maybe not worded the best way
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 03-06-2003, 02:36 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Pull off the mouldings
Sand down to bare metal with a 80grit sandpaper
bondo, or body filler, whatever you have
SAND-SAND-SAND
start with a 80grit, move to 120grit, then finish off with a 300grit.
I'm starting this on my car when the weather warms up.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 03-06-2003, 02:40 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
u can use bodyfiller but i prefere 2 use fiberglass, it goes over nice and easy and if u choose 2 use bodyfiller u'll see one of the probs with it, it likes 2 drip down inside the door and takes a longer time to do it.
Old 03-06-2003, 02:47 PM
turbcivic's Avatar
turbcivic turbcivic is offline
What the hell!!!
NEVER USE BONDO FOR MAJOR BODY WORK LIKE SHAVING!!!
Weld some metal to round out the spot for the molding, and then use a little bit of bondo to smooth it up. Fiberglass also works nicely.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 03-06-2003, 02:54 PM
I agree bondo is shitty. And Fiberglass is HELLA hard to sand.
my solution ??
DURAGLASS <<<------- That shit is strong, if it's preped right, you wont have any problems
||JEFF| |
Old 03-06-2003, 05:26 PM
i like marglass the shit is nice. and it is thick but i agree welding is the best way but if you arnt skilled you will warp the thin metal on your door and that aint good.
95 b18b
Old 03-06-2003, 05:30 PM
1PhatCX's Avatar
if u want all metal, fill it in with weld and grind all thats sticking out off, haha nah i'm j/p but i'm sticking with using fiberglass, i love it and its not hard 2 sand, well for me anyways, i got body files and stuff so that helps and sanding just smoothes it out for me
Old 04-14-2003, 10:51 AM
Coolstr85 Coolstr85 is offline
ok so wait. if i use fiberglass first, and then just fill in the tiny divits and stuff with bondo, should i be ok? or should i find someone to weld a metal piece in there? if i just use the fiberglass and the bondo will lines show? thanks.
Old 04-14-2003, 01:19 PM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
DONT use just bondo. i tried this and if u push on it when its done it pops out. it will fall out anyways sooner or later. Im still working on techniques to fill the damn holes in.
Old 04-14-2003, 01:47 PM
Civic Rush's Avatar
Civic Rush Civic Rush is offline
Send a message via AIM to Civic Rush
come on you guys.....ok if you were to use fiberglass you WILL NEED to put something behind it unless you want to replace it all of the time....
The reason for it is beacause....well think of it like this you are covering up a hole with a peice of paper....sure it looks good but as soon as it get bumped into......POOF broken....so I would either put in something behind it or weld something in there....just my 2 cents
This is the real melt pizzle
Old 04-15-2003, 04:38 AM
use marglass it is a very thick filler that contains fiberglass stands
95 b18b
