Budget Build 2008
Hey guys.. I am doing a budget build on my red VR4!
Goal- 450WHP for less then $1000 (Useing mostly Garaged parts) Motor->$500 Used Factory Rods-$50 Grind used crank-$90 Head Gasket set- $90 Bearings- $50 Pistons- New rings used set. or Topline Piston set??>$200 Used Heads- Free Power->$300 Walbro- $50 injectors- 550cc- Must sell the 450cc I currently have in it. >100+450cc Custom TD05 Manifolds- Free SAFC II- Have already Wideband- Have Twin 14b Turbos- $100 Custom oil and coolant lines- $30 Manul Boost Controller- Free HHH Datalogger- Have Custom Downpipe/Dump pipe Free ish What pistons do you guys think I should use? Used Factory with new rings or Topline W/rings? |
Re: Budget Build 2008
14b's eh? those are DSM TD05s right?
Do the toplines change the compression at all? |
I am dieing to get this thing running.. I am hoping less then 3 weeks I will be done.. Jason oh.. who wants pictures? |
Damn that will be impressive for the price! I want pics!
2005 Saturn Ion Redline - Injector Dynamics 1000cc Injectors|E85|Harrop TVS1320 Blower|2.9" pulley|3" Intake|Vibrant Header and catless Downpipe|Hahn 3" catback|N2MB Wot Box w/2-step and no-lift shift|Cobra Heat Exchanger|Hurst STS|Ottp Stage 1 trans mounts|AEM EUGO Wideband|Aeroforce Interceptor|HPTuners (self tuned)|Mop Top Pros Carbon Fiber badges|B&G Springs
![]() what kind of modifications (besides the manifolds) have to be done to get them in there? it's too bad boring out your block would put you over budget. 20 over would be badass. +1 for pics |
Yeah.. but I got a stock bore block that is in great shape too.. if I needed bored I can get it done for cheep.. and stay under the 1000 but go over the 500.. and I will take pictures of thecustom manifolds.. Other then the manifolds I need to make new custom lines.. just going to evoco hose of hose.. (I got a deal with them then i am using 2 dowpipes for the eclipse to make my downpipe! haha Its going to look like ass.. but its going to work!Jason |
Also, you may want to consider upgrading your clutch as well or else you will burn it up real fast, especially if your on the stock clutch. I know the stock clutch couldn't hold the power on my friend's BPU RT/TT.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
Yes indeed I didn't think about the 02 on the rear.. Good point.. Just a little more welding not to big a deal I had to custom make the down pipe anyways.. Thanks for the heads up! and it has an RPS Max with less then 1k on it! with a fidanza flywheel that was put in at the same time.. |
If this works, you just might have your first PMP 3/S turbo kit!
Black 1997 3000GT ![]() Quote:
HAHAHA so true! haha Getto as ever!! haha
Actualy We are working on our new 13g 15g and 19t Turbos!! I am very excited about it!! |
Ok I need to take some pictures.. and post!! I am going to put the motor together on saturday and get it ready to drop in.. then I am going to fab my manifolds and downpipes (Dumping under the car) and then I have 4 Races set up.. Evo X with bolt ons, Evo 8 lots of bolt ons and cams, mustang cobra ran a 12.3, and a 240 with the SR20det swap fully built..
damn man you didnt waste any time!
make sure to get some vids from those races too if you can. |
Finaly!! I got some pictures!! sorry this took so damn long!! and I was supost to finish this by friday.. but my Frickin turbo never showed up1! AAARRR
