Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 05-25-2008, 12:36 PM
DaveS268 DaveS268 is offline
Which Gear when Towing a Trailer?
Hi,
I have a 2004 Montana with the trailer provision, HD cooling system, and load leveling air shocks. I will be towing about a 1500 lbs trailer, which gear should be used? My owners manual isn't real clear with the installed towing equipment saying that I can use "3" rather than "D". Gas mileage seems to be better in "D" but then again if it puts undue stress on the transaxle I'd use "3".
Thanks,
Dave
Old 05-27-2008, 08:39 AM
Nitro23 Nitro23 is offline
Re: Which Gear when Towing a Trailer?
The key point to towing is how hot the trans gets. When you run in third gear, the motor runs at a higher rev and thus the trans fluid flow increases. This in turn keeps the fluid cooler.
If you have an extrernal trans cooler (like a mini radiator for the trans fluid) then you might be okay in OD.
Whenever I tow my boat, I never use OD. And I have a trans cooler.
Old 05-27-2008, 08:48 PM
Thanks for the advise, Nitro, how much weight are you towing? I have the towing package which includes the heavy duty cooling system so I should be able to keep the transaxle fluid cool.
Dave
Old 05-28-2008, 01:48 PM
I tow a 20 ft ski boat. I use my Full size bronco though.
I have only towed small trailers with my Montana, and never really worried about it. Only because they are short trips. On long trips it makes a big difference. Again it's the heat factor. When the motor is running at low RPMS (OD), the trans is not cooling as fast and heat builds up.
I did burn up a tranny in my Suburban towing the same boat. I was in OD when it let go. Trans shop told me not to use OD. Since then, still towing the same boat, never use OD. Have never had tranny issues.
Old 05-28-2008, 10:26 PM
Thanks for the advise, Nitro.... I will be using 3rd gear.
Dave
