Old 03-05-2003, 09:38 PM
SIvic SIvic is offline
Unhappy Clunking noise ???? PLZ HELP !!
ok guys, I got a problem with my hatchie. I believe this problem is getting worse because the noise keeps getting worse..
when I take off from a light I hear like a click / clunk from the front end like the wheel is being shifted back or forth.... I also hear it when I apply the breaks hard...
could this be a radius rod? I really have no Idea what it is and hope to get it fixed really soon..
btw....it isnt the motor because they are brand new mounts with polyurathane inserts.
Old 03-05-2003, 09:42 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
DUDE its your c/v shafts change them asap
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 03-05-2003, 09:45 PM
ok, I can see it would be my CV shafts when I take off from a light, but how come when I start braking???????
Old 03-05-2003, 09:52 PM
Cjz89civic's Avatar
AF Premium User
If you have the clutch out and slow down it will do the same thing cause you are just moving the shafts the other way still causing it to make nosie . The only time you may not hear it is when you are not exelerating or when the clutch is depressed and your coasting.
Old 11-18-2005, 07:19 PM
mrjoeshmo mrjoeshmo is offline
Send a message via AIM to mrjoeshmo
Question Clunk
Hey..I changed both of mine..and it's still doin it..any other ideas of what it could be?
Old 11-18-2005, 08:04 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Clunking noise ???? PLZ HELP !!
does it do it when you rev the motor or just when your driving ?
Team Lonely Drivers
Old 11-29-2005, 09:46 PM
lokmanhakim lokmanhakim is offline
clunking noise
Hi,i had facing the same problem before.when i did check out at the workshop,the mechanic so surprised because the tyre nuts getting lose!then the same problem coming in!after making a few details, the mechanic determined that the brake calipers (the steels that holding the brake pads) rubber bush are damaged.you need to check it out.hope these could help.
Old 11-30-2005, 07:41 AM
91CRXTC's Avatar
91CRXTC 91CRXTC is offline
Send a message via AIM to 91CRXTC
yeah my buddy had possibly the same problem, turned out he hadent tightened his lug nuts enough and they came loose. check them nuts!
The Evil Sleeper
