Go Back   Automotive Forums Car Chat > Jeep > Liberty
Old 05-24-2008, 11:19 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
05 Liberty Coolant Leak
I am working on a 2005 Jeep Liberty that has a coolant leak, but I cannot find the leak, I had the system under pressure for about an hour and had to ass coolant twice in the reservoir. It is loosing pressure but no visible leaks, Check Radiator, all hose connections, Water pump, no visible leaks at all and you can deffinatly smell the coolant burning.
I was just checking to see if anyone has had any similar problem, or if the intake manifold is a possiblilty, or common issue, like on the 3.9L, 5.2L and 5.9L.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 11-27-2010, 03:07 PM
AlphaCrow AlphaCrow is offline
Re: 05 Liberty Coolant Leak
Have 05 Lib and it's leaking on the water pump gasket, from underneath where you need a mirror.
