Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 05-24-2008, 11:13 PM
trefiak trefiak is offline
97 towncar no headlights
all of a sudden I have No leadlights on auto or maneul and no daytime runnig lights all other lights work
Old 05-25-2008, 02:08 PM
Towncar's Avatar
Towncar Towncar is offline
Re: 97 towncar no headlights
You must check the obvious first, a VOM will suffice:
Bulbs and Fuses:
  • Bulbs
  • #4 (10A)
  • #6 (10A)
  • #15 (15A) or Circuit Breaker 12 in the fuse junction panel.
REPLACE any open bulb(s), fuse(s) or circuit breaker as required.
The Multi-function Switch, and LCM are next.....
For information on fuses, breakers and fuse maps.. see your owners manual from page 183 to page 192. Here's a copy of that section.
Your full manual can be had from here.
-Steven
1996 Town Car, Cartier
Old 05-25-2008, 04:28 PM
Checked all fuses and Circuit Breaker all are good another thing is hi beam light on dash does not work eather.
Old 05-26-2008, 01:36 AM
ltdltc ltdltc is offline
More then likely you Turn signal stalk needs to replaced. Happened to me.
Find any 1995-1997 Crown Victoria/Grand Marquis/Town Car turn signal stalk at the junkyard and take it (certain trim levels do not have chrome on them FYI). Its a simple job, maybe 20 minutes if you have to fight the column adjust lever.
Richard
1995 Lincoln Town Car Signature Series
Past
1992 Lincoln Town Car Cartier Designer Series
1992 Lincoln Town Car Executive Series
1990 Lincoln Town Car
