Old 05-24-2008, 12:24 PM
thisismylife thisismylife is offline
axle
1987 jeep Cherokee it has the 4.0 in line 6 on top of the front axle there is a line where dose it hooke up to I found me hanging and don’t know where to hook it up to and is it a vacuum thanks
Old 05-24-2008, 01:14 PM
soldierp89's Avatar
soldierp89 soldierp89 is offline
Re: axle
i am not familiar with the 80s cherokees. However since i have an 89' wrangler, i believe, if the wires are on the passenger side of the axle, they are for your 4x4 vacuum pump. when you engage 4 wheel drive, it uses a vacuum to lock the outer shaft to the inner shaft. they changed this over in the 90s i believe because my 94 doesnt have it. you should have like 4 wires connect to a harness. check around there and see if you have an identical harness to plug it into.
89' YJ / 95' YJ / 94' XJ
4.2 L I6 / 2.5 L I4 / 4.0 L I6 HO
5 Spd. AX 15 / 5 Spd. AX 5 / AW4 3 Spd. W/ OD
4" Rough Country / 4" Pro Comp
Mickey Thompson 33/11.50/R16
BFG Mud Terrain 33/12.50/R15
Old 05-25-2008, 06:30 AM
gtmud gtmud is offline
Re: axle
FfOLLOW THE LINE, does it go to the top of the round portion of your front diff? If so this is your vent tube for the differential, just tie it to something higher than the diff and you'll be fine.
Old 05-25-2008, 10:23 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: axle
Usually it is tie wrapped on the firewall to a metal line.
Old 05-25-2008, 01:32 PM
Re: axle
It do go on top I dinette want to hurt it and ill tie it up and call it good thanks
