Idle Problem ?
In park or nuet. idle is fine. When I drive it goes up to about 2000 and won't come back down until I make a complete stop. ?? I replaced isc and reset everything. Any idea??? 93 Eldorado
Re: Idle Problem ?
Have you cleaned the throttle body and plates?
Re: Idle Problem ?
Yes I did. Thanks.
Re: Idle Problem ?
What are we working on car or a truck 4 or 6
Re: Idle Problem ?
93 Eldorado 4.9L
Re: Idle Problem ?
Is the ISC adjusted correctly?
Re: Idle Problem ?
Yes. I believe so.
Re: Idle Problem ?
Any binding in the throttle linkage? How did you adjust the ISC?
Re: Idle Problem ?
I removed isc control took idle to 550. Had the plunger on isc all the way in. It was about 1/4" from throttle when I put it back on. ??
Re: Idle Problem ?
With the base idle at about 450 and the ISC fully manually retracted and unplugged, I set my clearance at .030. Seemed to work well.
