Old 05-24-2008, 08:27 AM
knl25 knl25 is offline
Recharge the AC
How do i put R134a in the Windstar. Is it the black cap on the vertical tube in front of the engine?
Thanks
Old 05-24-2008, 12:02 PM
mundy5 mundy5 is offline
Re: Recharge the AC
Normally the refrigerant is put into the Low pressure line. In order to safely do this, you really need to know the pressure on both the high and low pressure line. If your van is leaking though, this would be a regular maintenance item for you and potentially might be at best a very temporary fix. It's up to you, but if it is leaking badly, it's better to fix the leak first b/4 adding more refrigerant. The dye test is the best at figuring out where the leak is.
2003 Windstar LX
1998 4dr Civic LX
Old 05-24-2008, 12:20 PM
Re: Recharge the AC
There may be a very small leak as the AC is still cold but not as much as before.
So which one is the low pressure line?
And can i do the leak test with dye myself? or does this require special equipment?
Old 05-24-2008, 12:38 PM
Re: Recharge the AC
I don't know if you can do the test yourself. Normally it is done at a shop. Maybe others can chime in.
Regarding the low pressure line, it should have a blue cap and a capital L on the top. the high pressure line should have a red cap and have a capital H on it.
2003 Windstar LX
1998 4dr Civic LX
Old 05-24-2008, 06:15 PM
Re: Recharge the AC
just recharged with a kit from walmart (to the black cap with the 'L') and the AC is very cold now.
hopefully it will stay cold for the summer.
thanks for the help.
Old 05-24-2008, 08:11 PM
Re: Recharge the AC
congrats knl25, I hope that kit had a pressure gauge so that you don't overfill the refrigerant. how old is your windstar? I'm thinking I need to consider doing something similar in about 2-3 yrs. Right now, the a/c is very cold.
Also to prevent more leaking in the future, you really need to make sure you are running the A/C all year round at least once a week.
2003 Windstar LX
1998 4dr Civic LX
Old 05-24-2008, 08:17 PM
Re: Recharge the AC
Mine is a 2000. The kit has a gauge and it took a whole bottle to get to the normal pressure range.
Last year the van's AC was very good, but I do not turn it on at all throughout the winter and fall. I'll remember to use it once a while.
Thanks
Old 05-25-2008, 06:12 AM
wiswind wiswind is offline
Re: Recharge the AC
Actually, you most likey are turning it on in the fall and winter.
The A/C is "ON" when you have the controls set in any position that includes the defrost.
It will NOT , however, actually engage if the temperature is real cold outside.....but otherwise, it will be cycling when you are using the defrost or a blend of defrost and floor outlets.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
