Old 05-24-2008, 12:34 AM
Im1crazymf Im1crazymf is offline
Which seats will fit?
Just picked up an 89 Civic hatch and the seats are destroyed.
Can anybody tell me if there are any other types pf seats which will fit beside the racing seats.
Thanks all
Old 05-27-2008, 01:22 PM
b16crx91 b16crx91 is offline
Re: Which seats will fit?
88-91 civic hatch seats will work or you can manufacture a way to make crx seats work
Old 05-27-2008, 03:09 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
That would be fabricate, not manufacture. You should just be able to swap the seat rails over for the CRX seats.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 05-27-2008, 03:19 PM
tried that one didnt work! and i ment manufactured i know the proper term is fabricated but.........
Old 05-27-2008, 04:31 PM
Tony's Avatar
TLD Member #1
I haven't had to go through the process, but I'm sure its not difficult. People make different seats fit in their cars all the time. If you want a simple direct fit, not modding needed, just get some hatchback seats and slap in there.
Tony
Old 05-27-2008, 06:27 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Yeah you CANT just take crx seats and slap hatch rails on. Hell, I couldn't even get 91 crx si seats into my 91 crx dx. I had to pull the metal pan off the bottom of the seat and swap them. But I got my seats in there DAMMIT!
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 05-27-2008, 07:15 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
custom rails are almost always needed for seat swaps.. for some reason, Honda decided they didn't want you swapping seats... hell with engines, just can't have the seats.
Hatch seats, yes, CRX seats if you change the seat pan or the whole back, any other seat you want if you make the rails fit, which isn't hard.
Old 06-01-2008, 11:04 AM
zachzula's Avatar
zachzula zachzula is offline
DelSol seats fit in rex's pretty easy so I cant imagine there would be much of a problem in a hatch. They set lower too. Great if you have the si sunroof.
ZACH!
89 CRX SI
http://www.crxcommunity.com
Old 06-01-2008, 01:50 PM
Yeah, except hatch seats don't fit properly in a CRX either. Apples and oranges, buddy.
Old 06-02-2008, 06:36 PM
zachzula's Avatar
Yeah...thats kind of the point I was making. Just saying the delsol seats sit low. Still have to be modified for a hatch or rex. Just not that difficult.
ZACH!
89 CRX SI
Old 06-02-2008, 08:01 PM
K, the post was a lil confusing... made it seem like you were saying that CRX seats were a direct fit.
Old 06-02-2008, 08:32 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
easiest thing is to find some 88-91 hb seats and put them in...if you find a set that you want or can get a good deal on, then we'll go from there
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 06-25-2008, 05:26 PM
rusted rusted is offline
OK, I'm confused^2....
I have a 91 CRX DX. What seats will fit it? I don't necessarily mean drop in; I can drill/grind/braze/ etc...
The yard of bones has various Civics, Del Sols, etc but no CRX's much less one with good seats...
ps: said yard now pays $300 per car, any car, any shape. I see LOTS of "it was in the backyard for 20 years but for that $$$" cars.... two 70's 450SL [each 4600#'s of steel!], a Rover sedan, a MG, some 544's...
Old 06-25-2008, 08:25 PM
anything will fit if you can modify it.
best idea is usually to stick with something of the same year, same manufacturer.
ANYTHING you put in other than racing seats and stockers will require SOME mods.. but the extent is up to you.
Old 06-25-2008, 09:46 PM
The bench seat from my friend's Duster????
My question is about basic dimensions of various Honda seats. Some will be wider, longer taller that will fit in the available space. I'm just wondering if anyone has direct knowledge "Yes, a XXXX seat will fit in a CRX {without chopping off 6" excess width}..."
