Go Back   Automotive Forums Car Chat > Chrysler > LHS
Old 05-23-2008, 11:22 PM
kemopar kemopar is offline
Replacing front wheel bearing on 95 LHS
I have to replace the right front wheel bearing. There are 3 bolts that connect the bearing assembly to what I believe is the steering knuckle. The two lower bolts are no problem, but I cannot get a wrench on the top bolt to remove it. The CV joint is close and blocking access. Is there a way to remove this bolt with breaking down the suspension? Is there a special tool for this job? I'm thinking of grinding down an 18 mm socket.
