Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-23-2008, 05:58 PM
89rscamaro 89rscamaro is offline
1989 Camaro starts then dies immediately
I have a 1989 RS camaro 305 TBI the car died on me a few weeks ago.
The car would crank but not start. After finding no power to fuel pump relay I replaced the computer. Now the car starts but dies immediately. I have spark and fuel any ideas would be greatly appreciated.
Old 05-23-2008, 06:37 PM
chevyrulespops's Avatar
chevyrulespops chevyrulespops is offline
Re: 1989 Camaro starts then dies immediately
The first thing I would have to do is check for a code!!! the computer might have something that can help start you in diagnosing the problem....let us know
Old 05-23-2008, 07:05 PM
There is no troublecode now there was before i changed the computer. I hear the fuel pump whine now,the car starts fine but immediately dies.
Old 05-23-2008, 07:13 PM
I have 13 volts at battery and alternator fuel pump whines in tank, battery volts at coil and distributor. Good spark the car starts fine but then dies immediately after.
Old 05-23-2008, 08:44 PM
mikeemon's Avatar
mikeemon mikeemon is offline
Try testing the fuel pressure.
Old 05-23-2008, 08:50 PM
Is there any way to test fuel pressure without a fuel pressue gauge.
Old 05-23-2008, 11:27 PM
Morley Morley is offline
Ummm, not really. take the air cleaner off and have a look down the throttlebody while someone starts the car. You are looking for the injectors to be giving a good strong spray. If they aren't, change the fuel filter and try again. If they still aren't spraying strong you'll need a fuel pressure gauge.
Make sure the injectors aren't blasting fuel in too, this will flood the engine.
Old 05-24-2008, 06:50 AM
Do you know what that trouble code was? If your fuel inspection is good this problem might be pointing to a faulty module or some faulty wiring to the distributor, double check your fuses also. The computer that you grabbed, where did u get it?
Old 05-24-2008, 01:43 PM
The troublecode was 54, fuel pump circuit low volts. The computer is a reman from Oreilly's. I can hear the injector pulses and see good spray of fuel.
Old 05-25-2008, 12:09 AM
I just got a fuel pressure tester only have 2 psi with return line clamped shut, filter is new so now I'm replacing fuel pump.
