Old 03-05-2003, 07:55 PM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
Stumped on this motor...
Okay I put my new motor in about 3 weeks ago. I have since replaced the dizzy cap and the rotor along with the fuel filter. I now notice that I am losing oil. About 1/2 quart every 100 miles or so. I have been told that could be bad rings or a valve seal. If I let it idle for about 5 mins it will create a damp spot about 3 ft long and a puddle about 1/2 ft. long behind the exhaust tip. Its water as I smelled it and its clear when I run my finger through it.
There is a knocking sound as if a rocker arm is coming off the valve. Could that be caused by having a different cam than stock? If not could it be the seal or did the jackass that did the cam work not set the clearances right?
Anyways if you have any thoughts on what the hell could make my car burn oil and leave a water puddle behind the tip tell me what you think.
Old 03-05-2003, 08:02 PM
Registered User
Its an A6 just like stock but with the mods listed down there
Old 03-05-2003, 10:27 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
probably a dumb question, but did you replace the head gasket? also check for oil leaks by the oil pan......
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 03-06-2003, 05:25 AM
Registered User
There is no oil leaking from the engine I have been under the car like at least once a week since the engine was put in.
Old 03-06-2003, 09:09 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
I dont know if this is the same knocking your talkin about but my friend's ZC motor made that loud ass knocking noise. We were tryin to figure out was wrong with it. SO we did a valve adjustment but that wasn't it. Then 2 days later his camshaft broke in half while driving!!
Old 03-06-2003, 02:12 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
if your not leaking oil from teh enigne, then its either valve seals or rings. is your exhaust smoke all blue ?
Old 03-06-2003, 02:31 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Re: Stumped on this motor...
I get this too, it has me Hella confused!! i dunno why it does that and my car shoots blue smoke when i rev it high while in neutral, i've run it on really cold days tho so when it idles i dunno if its smoke or just steam or w/e that is lol, but someone told me I have condensation in my muffler and thats where the waters coming from but it doesnt stop.... also, i just replaced my valve seals so i think they need 2 be worked in for it to stop burning oil, i dunno, if it keeps it up then i'm gonna be pissed, it'll b another 200 bux for a gasket kit when i do all the piston rings and shit! sorry, had 2 vent on that. i hope all ur problems get fixed man, and if u find out the reason for the water coming out the exhaust then lemme know cuz I think it might be more then just condensation
Old 03-06-2003, 02:39 PM
turbcivic's Avatar
turbcivic turbcivic is offline
Wow, i thought it was just me that was having this problem. One of the techs at work told me piston rings or exahust vavles guides.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 03-06-2003, 05:57 PM
redmanjd redmanjd is offline
when i blew my motor . my car smoked when i reved it up cause the seals were gone on the valves pull your header of and see if you see oil. be then i spun a rod bearing and shavings of the bearing scared the cyl walls and it started knockin
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 03-07-2003, 07:13 AM
Registered User
This morning my check engine light came on its code one so the o2 sensor is dead. I will replace it this week and see what happens
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
