Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 05-23-2008, 04:04 PM
wmsimcox wmsimcox is offline
Coolant Level Sensor?
Have an 03 Envoy. Check engine light is on. Check code. Says engine coolant level low. Check coolant. Full, right where it sould be. Check auto parts store, they have sensor. Go to Haynes manual, nothing about engine coolant sensor. Can anyone tell me where it is located?? It's pretty inexpensive, but I can't figure out where it is.
Thanks for any help.
Old 05-23-2008, 07:09 PM
maxwedge maxwedge is offline
A990 racer
Re: Coolant Level Sensor?
Do you mean coolant temp is out of range or low? This is a different issue. What was the code?
Old 05-23-2008, 10:36 PM
Thanks for responding. Went back and had them check it again and read the read out myself. It is the coolant temp is lower than the thermastat.
So that would be the coolant TEMPERATURE sensor. Figure it must be the sensor as the temp gauge is in it's normal operating range.
Thanks again.
Old 05-24-2008, 08:07 AM
A990 racer
I'd get a scanner on this and see what the actual temp is, it could also be the the T'stat.
