Old 05-23-2008, 03:32 PM
yhandor's Avatar
yhandor yhandor is offline
Send a message via MSN to yhandor
97 Z24 Issues Again, Ffs...........................
Hey all,
My new 2.4 has ran awesome, until I changed the spark plugs yesterday, put in NGK Iridiums.......ever since its been hard to start, and idles ROUGH and sometimes dies........so I put my other plugs in, same thing, then went and bought another brand of plugs, same thing, so I went and got 2 extra 2.4 IDI covers and tried all 3, same problem..........I cant figure it out..............it ran perfectly fine until I changed the spark plugs, now it runs like shit.......no matter what brand of plug I put in, or anything, DEPSERATELY NEED HELP!!!
Old 05-23-2008, 05:41 PM
kirkwood158's Avatar
kirkwood158 kirkwood158 is offline
Re: 97 Z24 Issues Again, Ffs...........................
I know this don't sound right but try the ICM one more time as I had simular and this did take care of it for me
spark is controled by crank sensor
cam to some degree and ICM
I installed diferant un till it cost about 600.00 for every thing new twice of course and found my ICM ....only ran on two cylinders and that was some times. and at other times ran great ICM tested good origanalluy also.
check plugin and wires at the ICM later
IF I JUST DID IT RIGHT THE FIRST TIME
Old 05-23-2008, 07:12 PM
yhandor's Avatar
Well I tried 3 IDI covers so I dont think its that, I pulled all the brand new plugs i put in this morning, and the #2 plug was soaked in gas. Whats this mean? I know it means that cylinder isnt firing(getting spark) but its like that with all 3 covers......and 3 covers arent bad my original worked perfectly fine before I originally changed the plugs.........HELP!!!
Old 05-26-2008, 04:51 PM
yhandor's Avatar
Hey Kirk what is the ICM and where is it located? So far I have tried several IDI covers(the 2.4 Twin Cam cover), tried every brand of spark plugs, tried new Camshaft sensor, new MAP sensor and checked the computer to make sure it wasnt corroded, and still runs like shit.......I cant figure it out
Old 06-08-2008, 02:39 PM
yhandor's Avatar
Okay well heres what I have tried:
Spark plugs
IDI Covers
Camshaft Sensor
MAP Sensor and vacuum line
ICM sensor
Injector Cleaner
Fuel Pump relay
Fuel Pump
still runs like shit, Im getting on the verge of selling it, I have now run out of money and it still runs like shit. Anyone got $4000? Take the thing away.
Old 06-09-2008, 01:10 AM
yhandor's Avatar
Today I tried:
Computer change
Compression Test(compression is normal)
Spark test(Plug wires from IDI cover to plugs, removed one by one, got lots of spark)
New Fuel Filter
Throttle Position Sensor
Still runs like garbage. Any help? PLEASE!
Old 06-09-2008, 01:53 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
someone I know has the same issue, mystery problem and they replaced everything but the engine harness. Its a 5 speed convertable for $1,000
lol, less miles too.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 06-09-2008, 01:55 PM
Lifted GMT-360!
Did you get gas right before this started to happen? We had another issue of the same matter over the weekend at the shop. Someone came to use with a mitsu spider and it just wanted to die... poured in about 5 bottles of octane booster, and went rampant on the bitch... Fixed her issue.
Might just have bad gas bud.
Old 06-09-2008, 02:04 PM
yhandor's Avatar
Ill get some fuel injector cleaner and get gas at a different place instead see what happens!
Old 06-09-2008, 02:55 PM
muff34 muff34 is offline
Want some good injector cleaner go to Gm dealer ask for ACDelco fuel system treatment plus. #88861012. Expensive stuff but will clean it out if it`s gummed . around 17 bucks a bottle .read intsructions before you use it . Leave the cheap stuff on the shelf at Crappy Tire. Going to a different filling station ,go to Shell or Petro Canada. they put additives into help keep it running smooth as well.
Good luck Muff
Life Is A Highway ,Enjoy The Ride
Old 06-10-2008, 10:39 PM
yhandor's Avatar
Well my dad bought me Motomaster Injector Cleanr, got gas somewhere else and put it in, no difference yet, the fuel pump i put in last week however, made it a bit better, like it will run fine when its going now, its still hard to start thoguh and smokes when it does, black smoke, that smells like raw gas
Old 06-12-2008, 01:21 AM
yhandor's Avatar
Also got a code to the other day, it was P017X - System Too Rich (Bank 1).....anyone know what that means? Could it be whats wrong?
Old 06-12-2008, 11:48 AM
front oxygen sensor is detecting too much fuel. are you sure you did not bump something when you did yor plugs .maybe double check things . everything went for a crap as soon as you did the plugs so it would make one think you`ve accidentally disturbed something
Old 06-12-2008, 02:34 PM
yhandor's Avatar
Everything has been checked lol, i just cant figure out whats wrong, it seems when i shut the car off fuel still goes into the cylinders and when i start the car back up i have to hold the pedal down and it smokes black and smells like gas.....could a leaking injector be the problem? Putting gas into the engine after i shut the car off?
Old 06-13-2008, 02:21 PM
yhandor's Avatar
Heres a link to my YouTube video of what it runs like.......this may help you figure it out?
http://www.youtube.com/watch?v=Y6wKJ54jIG8
