Old 05-23-2008, 12:54 AM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
moving drivetrain foward about 3" in 78 c-10 pickup
im looking at picking up a 78 bonanza c-10 pickup with a good running 76-older 350 4bbl engine in it but dead th350 trans
i have a 3L80HD from an 87 c-10 pickup but they are 34.5" long overall in which is 3" longer than a truck 9" tail TH350
i have no drive shaft that is the required 71" from the end of the tranny tail back to the axle yoke u joint in which is 3" less than the 74" that the sbc and 9" tail trannies had
we have no driveline shop in central IL that touches driveshafts and even if we did it would be way more $ to have one shortened than id be willing top spend on an old rusted out beater trailer hauling rig
does anyone know if there is at least 3" of space in front of the clutch type fan blades on these and the backside of the radiator ?
if i can modify my trans linkage with the welder then i should be able to do this easily since the engine mount frame brackets will slide forward on the frame rails without any trouble
the fan to radiator clearance is the only trouble i can see
im pretty sure that i still have a 94 ford taurus electric fan laying around though, if i really had to use it i could rig it in there i guess hmm
thanks
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 06-23-2008, 04:02 AM
rockwood84 rockwood84 is offline
Re: moving drivetrain foward about 3" in 78 c-10 pickup
it would be easier to cut the drive shaft the three inches. cut the driveshaft close to either end front or rear. tack one side then roll driveshaft over tack the otherside and so forth till you have four tacks.roll the driveshaft on good level flat surface and make sure it is even all the way around then get someone who can weld and weld it . most people cut the driveshaft in the middle and that don't work.i've seen some use a square on the shaft to get it even.
