Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-22-2008, 11:13 PM
blackcell3 blackcell3 is offline
Boost Question.
Ok, so I am most likely going to purchase a 98 GST here in the next week or so. It has a fully built engine (forged internals and the works), some head work, and all supporting mods. The engine only has 2000 miles on the rebuild. BUT it only has a 1st generation turbo on it, im curious how much boost I can safely get out of that turbo and how much horsepower it could make?
Old 05-23-2008, 12:07 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Boost Question.
About 18psi and around 275 whp maybe.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 06-07-2008, 09:25 PM
jeremytalon92's Avatar
jeremytalon92 jeremytalon92 is offline
Re: Boost Question.
http://en.wikipedia.org/wiki/Eagle_Talon
only i dont know if they are talking about the 14b turbo or not
kosei black powdercoated 16'' rims,hyoshi muffler,removed smaller honeycomb in maf,ngk wires and plugs,luk clutch and pressure plate,stock flywheel,traction t/a bfgoodrich tires,silverstar ultra headlights
Old 06-07-2008, 11:15 PM
steviek's Avatar
steviek steviek is offline
Re: Boost Question.
It is certainly likely that the level of boost would not be the limiting factor in a car like that. With a built motor it could handle any amount of boost. The problem then becomes the "weakest link". Its the part which cannot fully support the turbo. For instance are your fuelp pump and injectors upgraded? These will be maxed out before the turbo. This holds true for so many things which are not designed for higher than stock boost levels. If everything is fully capable of supporting the 14b than you shouldn't even have to ask that just take the boost controller off and have some fun.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
