Old 05-22-2008, 09:56 PM
bbustums bbustums is offline
Overheating problems
I have a 94 Accord EX. A few weeks ago when the weather reached the hottest it had been this year in my area, I noticed the temp light which is usually at around the 1/3 mark, rose to a little above the 3/4 mark. Car didn't seem to be bubbling. It didn't do it consistently over the next few days, but when it did, it would act like this: rise to near hot when sitting at a light, and the second I take off would gradually drop down to 1/3 within 8-12 seconds of driving. I added some antifreeze and it acted fine for a couple weeks.
We were driving on a hot day two days ago, noticed the temp gauge going to near true hot mark level for the first time and discovered the heater hose blew. Got that replaced, drove around for around 12-15 minutes, and saw the needle rise to about the 3/4 mark. Took it right back to the guy who had just replace hose, he poured water over the radiator and we added some more antifreeze. The car did not overheat (weather had dropped a few degrees at that point if that should matter) during my driving the rest of that day,even with the car sitting idle and running for minutes at a time.
Today my wife drove it and the needle rose to near hot, she stopped to check and fluid had been leaking from somewhere. I fillled with water(some antifreeze was still in) and the needle did rise to to about 3/4 but I never saw any leaks. Funny thing is, when you press on the gas when idle, the needle goes down immediately.
What does it sound like the issue may be with my car?
Old 05-23-2008, 01:55 AM
mpumas mpumas is offline
Re: Overheating problems
Could be the cooling fan or temperature switch that starts the fan or a fuse for the fan. Could be a stuck thermostat. When you turn off the engine after running on a hot day, does the fan come on and run for awhile and then stop?
Old 05-23-2008, 11:58 AM
I may be wrong about this, but I thought I had always noticed both fans staying running when I cut the car off on a hot day, but now the fan directly in front of the engine doesn't stay on after the car is cut off. Should both fans stay on after the car is cut off and that could indicate a problem with the fan?
Old 05-23-2008, 11:14 PM
Both fans are only activated when you have the airconditioning on. So without airconditioning, one fan will run when the radiator gets to a activating temperature. This usually happens on a hot day when you turn the engine off. It also happens at other times but is not usually noticable because of engine noise and other things happening when the engine is running.
